Some home page changes
Discussion in 'RoadFighter WordPress Theme' started by birdgroup, Mar 19, 2014.
  1. birdgroup
    birdgroup Member
    Hello Inkthemes,
    I have already removed the "blog posts" and "testiomonial" from the homepage (I looked through previous messages)
    But I also want to remove the bottom section marked as "Any important with a call to action...." and the box next to it with "View portfolio"
    I then want to add this all as a text area.
    If this possible?
  2. birdgroup
    birdgroup Member
    Also is it possible to change the size of the 3 homepage images, they are currently set as 313 x 172, perhaps change to 313 x 313 so they are square
  3. Piyush
    Go to the front-page.php file present in your theme directory and follow the instruction shown in the image given below.
    Now go to the Appearance > Theme Options >Home Page Bottom Feature panel of your dashboard and put your text in the Home Page Tagline section.
  4. Piyush
     .feature-content .feature-content-inner.first {
    height: 313px;
    .feature-content .feature-content-inner .image-box {
    height: 313px;
    .feature-content .feature-content-inner img {
    height: 313px;
  5. birdgroup
    birdgroup Member
    Hi Piyush, my front page php file is blank?
  6. birdgroup
    birdgroup Member
    I am also looking for a text area on the picture below, can this be added easily enough?
    See picture...
  7. Nitesh
    Changes you are asking require customization in the html file. For it you need to follow process given in the post #3.
    Nitesh Raghuwanshi
  8. birdgroup
    birdgroup Member
    For some reason I have this issue...
    When I click on front-page.php it is blank???
    Help!
  9. birdgroup
    birdgroup Member
    I have sent in a support ticket, as now the homepage has vanished!!
    help please!
  10. birdgroup
    birdgroup Member
    Hello again, I seem to have sorted out www.spindles.co, but I now need to know how to remove the grey border at the header. I prefer it simply showing an image all the way across.
  11. Piyush
  12. birdgroup
    birdgroup Member
    Still the same???
  13. birdgroup
    birdgroup Member
    Can I not add a homepage? is that the issue?
  14. birdgroup
    birdgroup Member
    I need to add the meta data, and by adding a home page it works, otherwise it doesn't?
  15. Piyush
    Go to the Dashboard > settings > reading
    and set it to default as shown in the image given below.
    I hope it will resolve your problem.
  16. birdgroup
    birdgroup Member
    Yes but by doin git this way, with my Home page added within pages. Any seo work I add it doesn't show?
  17. Piyush
