Hello, I need some customization of the Lead Capture: 1. I don't need the "Price, Add Date Slot and Add Time Slot" options in the admin area 2. I will still need the "select date" field in the front end; and one "fill in field" for the time or "select time" in 24 hours format (each 15 minutes); one "fill in field" or select for "Number of people" I don't need the Price field 3. There is a possibility to change the color of the Lead Capture but it don't works. 4. Is it possible to have the Lead Capture form right after (bellow) of the slider area in the mobile and tablet view? At the same way as in the SmartBooking theme. Thanks & Regards Lyubo
Hello Lyubo, Greetings from InkThemes! Everything will be possible but it requires a lot of customization of source code and our time as well, As InkThemes has been receiving a high volume of support requests therefore, we will charge you for this customization, Do let me know if you agree then, I will tell you the amount and mode of payment. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hello Pryanka, after I checked the Lead Capture form again I noticed, that it not usable in this form in Europe. Not only the Time Format, the Day Format is unusable, too. The day format in Europe is 01.02.2016 - 01. February 2016 in your form is the US format and it means 02. January 2016. This Lead Capture form is completely not customize able. To customize the complete form for me would need a lot of time and I would not pay for it. I am paying the membership for some years now. I need the Lead Capture form in European date and time format without price field or instead of the Day, time and price fields three text fields to let the customers write the day, time and number persons. Or is it possible to put eventually one third party Lead Capture form at this place (It will be perhaps not so easy) Thanks & Regards! Lyubo
Hello! lyubo, We are not ignoring your queries, just delayed in reply. Since InkThemes has been flooded with lots of support request. Please accept my sincere apologies for this delay. Regarding, Date format, I would like to inform you that - We are soon going to release an updated version of the InkAppointment plugin with following features: 1) 3 Different Date formats. 2) Email Templating with reminder notification. 3) Appointment deletion, cancellation and approval The plugin is under development and our developers are trying their best in enhancing its features. Once it will be done, we will notify you. You cooperation and patience would be appreciated, Warm Regards! Naveen Kolhe InkThemes.com
