This is strange. I am using the newest version of Cloriato. If I am at the top level or home level of the dashboard, all the features which have drop down arrows seem to work fine. examples include: At a glance, screen option, help and activity.... If I drop down into an "edit post" page... none of these drop down arrows work... examples include: screen option, help, categories, format publish, etc... Also... many if not all of the test links work... for example the status, visibility and published-on features are all dead. Any advice? Thanks! Chris
Hi Chris, I have got your concern and checked the theme at our end, For your information, it may happen that some of your plugins are conflicting in your site, You are requested to deactivate all of your plugins once and check you site's again, Then activate one by one your plugins checking result on each activation, Hope this will let you figure out the messing up plugin. Do let me know if you need further assistance, Warm Regards! Naveen Kolhe InkThemes.com
Hi Naveen, That WAS the issue. THANKS! The offending plugin was the Donate plugin provided by InkThemes.... Any advice with that? thanks! Chris
You can deactivate that plugin and use an alternative. This will help you to figure it out and resolve the issue(s). Warm Regards! Naveen Kolhe InkThemes.com
Naveen, that's what I intend to do but.... it just seems like the plugins you provide with that specific theme should be compatible with it. Don't you think? cheers, Chris
Hi Chris, I would like to clarify you that, it's sometimes become impossible to test the theme with almost all plugins and as you know that, there are plenty of plugins available on WordPress.org but we will keep trying our best in testing the theme and plugins. Hope you understand, Warm Regards! Naveen Kolhe InkThemes.com
