Some spaces
Discussion in 'Appointway WordPress Theme' started by lyubo, Mar 4, 2016.
  1. lyubo
    lyubo Guest
    I made one background for the feature area, but the space between text and border was to little. Then I set
    .feature_content {
    padding-left: 10px;
    padding-top: 10px;
    It worked well but the third box gone under the two another boxes.
    I simulated it with the Firebug and I could change the margin of the boxes and it worked well, too.
    My issue is, that I make a syntax mistake in the custom css and I could not set it there. Here what I tried:
    .featurebox_desc first, .featurebox_desc second,
    .featurebox_desc third {
    margin-right: 10px;
    Can you say me what is my mistake? Please see the screenshots.
    Thank you!
    Could you please try below code and check after that....?
    .featurebox .featurebox_desc {
        margin-right: 23px;
    .featurebox_desc.third img {
        margin-top: 75px;
  3. lyubo
    lyubo Guest
    It works perfect, thank you!
    Great support!
    Thanks a huge lot for your appreciation...:)
