Sort by Rating
Discussion in 'GeoCraft WordPress Theme' started by cjohnosn, Apr 1, 2013.
  1. cjohnosn
    cjohnosn New Member
    Hello-
    I was playing around with the search form, and managed to add "radio" buttons, that add to the search command. This is easy and works great.
    I am wanting to make additional radio buttons for the star ratings. Do you know what I search command I should make the radio button call for? I want to sort the search results by a particular rating.
    For example: (this does not work... but you get the idea..)
    http://website.com/search/?sfrom=hotel&location=london&rating=4
    Thank you in advance.
  2. cjohnosn
    cjohnosn New Member
    any help with this?
  3. Piyush
    Unfortunately there isn't a way to do that with this theme unless you custom code something up. Sorry.
    If this isn't something you're able to do then you would need to hire a developer for this.
