My site is: http://tuguiaencastellon.es/guiaservicios/ I need to translate it, but not using google plugin because the translate is not good I need to translate: Search.... Location.... SEARCH LISTING Categories Recent listing Recent reviews etc How can I do it? I translate some word of the po and pot file but others are in the php files i dont find it! Is there any .po .pot spanish translation?????? I have to translate geocraft and classicraft themes and I have no time THANKS!!!
Hello, Search.... Location.... SEARCH LISTING these words are in po file. You can change them from there. Or if you want to change them manually then Go to the geocrafttheme\library\text_domains\template_path.php And change from there. For Categories Recent listing Recent reviews These are widget titles. You can change them from Appearance > Widgets > Home Page Widget Area
