Speed of Slider
Discussion in 'BlackBird WordPress Theme' started by mal2091, Jun 14, 2013.
  1. mal2091
    mal2091 New Member
    Is there a way to speed up the change between images used in the slider? It seems as if the image changes every 5 seconds or so. Can it be changed to 2 or 3 seconds? If so how do I go about doing this?
    Thanks for your help/advice.
    Mike
    Go to js > jquery.flexslider-min.js present in your theme directory and adjust the value of SlideShowSpeed by increasing the value the slider speed decreases,and by decreasing the value the slider speed increases.
    Sending image for reference
  3. mal2091
    mal2091 New Member
    Where do I find js>jquery.flexslider-min.js ? I assume its under Appearance > Editor...but then what template do I look under to find js?
  4. Gourav
    You will not get theme directory in your dashboard.
    You can edit jquery.flexslider-min.js file through FTP.
    Open your Theme directory (through FTP) > js
    Download jquery.flexslider-min.js file from there, Edit it, Then again upload it.
  5. mal2091
    mal2091 New Member
    I hate to be a pain but could you walk me through the process. I assume I would...
    1) Log into an ftp site
    2) Where do I look for the Blackbird Pro theme used in my Wordpress blog?
    3) What username/password should I use to access the Blackbird Pro theme used in my Wordpress blog?
    4) Download jquery.flexslider-min.js
    5) Edit it as you have stated above changing the slider speed number to a lower number to increase the playback time or vice versa to slow down the playback time.
    6) Upload the edited jquery.flexslider-min.js
  6. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    FTP Details:
    We will change slider speed for you.
