Spinning wheels not spinning and links not working
Discussion in 'Traffica WordPress Theme' started by mantix, Jul 17, 2016.
Tags:
  1. mantix
    mantix New Member
    Regarding the site :
    www.gallerifoto.se
    The Spinning wheels are not spinning and links not working well. (Homepage feature area)
    Regarding links not working. You have to click several times before it continue to the link added in the Home feature area.
    /Mantix
    Hi, Mantix..
    I have checked your site and didn't get any issue with the link..
  3. mantix
    mantix New Member
    It is only with Microsoft Edge (I'm using Windows 10) it doesnt work at 100 %
    Funny.. bcs with Internet Explorer i do not see the "background" / Other side text of the Feature, but the spinning are spinning and www link does work.
    With Chrome Everything wors well. I can see the background text and www. links works.
    /Mantix
  4. safdaarh
    safdaarh New Member
    I am having the same Problem with Font Awesome Icons not showing up:
    1. Everything works well with other Browser (Chrome) BUT NOT Micro. Edge. (especially the Pro. Version ICONs of FA).
    so what is the Solution to get the icons to appear under Microsoft Edge?
    thanks
  5. akbar92
    Will you please share your website URL here?
    Looking forward to hearing from you.
    Akbar
