Split Homepage Feature Area On Business Grow Theme Into Two Columns
Discussion in 'InkThemes-Support Working Hours' started by apaduano, Apr 26, 2015.
  1. apaduano
    apaduano New Member
    On the Business Grow theme, I would like to split up the Homepage Feature Area into two columns. I have attempted some obvious modifications focusing on using divs to create a container and individual columns, but it hasn't worked. Please advise.
  2. sameerwalkar
    sameerwalkar Guest
    Could you please provide your site URL along with some edited screenshot so that I can assist you accordingly. If you are unable to create edited screenshots than you can use http://www.screenpresso.com/ . It will help you to create screenshots.
  3. apaduano
    apaduano New Member
    The site url, as it has been in my other posts you've responded to, is: compoundsforhealth.com
    Here is what the new layout should look like (with the purple divider):
    *Note: The height of the div may need to be increased in order to fit all of the text. Also, the image depicts layout only. Ignore any changes in font or background
  4. praveen
    praveen Support Staff
    Praveen
