Squirrel Pro Editor
Discussion in 'InkThemes-Support Working Hours' started by rprevot, Feb 29, 2020.
  1. rprevot
    rprevot New Member
    Hi!
    Is there a way to edit or make changes on my Squirrel Pro without going to the actual Theme Editor?
    There should be a safer way to modify the theme in case something goes wrong.
    I'm trying to edit some pictures in the features section but afraid I might delete a php code.
    Your help is much appreciated.
    R
  2. shemaela21
    shemaela21 Guest Staff Member
    Thanks for contacting us,
    Yes, we do have theme options panel in our theme from where you can customize the home page text and images.
    And you can edit the feature images from your WordPress dashboard itself.
    Let us know what you are trying to edit in the images and how, if the query is something different then we will assist you in that way.
    Shemaela
