Squirrel Theme Footer Help
Discussion in 'Squirrel WordPress Theme' started by boldplanning, Jun 19, 2013.
  1. boldplanning
    boldplanning New Member
    Nashville, TN
    Please help! I am using the Squirrel Theme and I am having one continuous problem with the very bottom footer. When I place links into the footer area by way of the theme options my text will show up on the public facing end but randomly goes away after a few minutes or when another part of the site gets edited. The text links that I am trying to add to the footer show outside of the available text area and something seems to be broken.
    It should have the Terms of Use and Privacy Policy links next to 2013 Bold Planning. www.boldplanning.com is the website address.
    THANKS!!!
    Go to
    Appearance > Theme Option > Footer Settings > Footer Text
    and add the code given below
    © 2013 BOLDplanning, Inc.&nbsp&nbsp&nbsp<a href="Enter your link address">Terms of Use and Privacy Policy links </a>
  3. boldplanning
    Nashville, TN
    Thank you for the response. I have done that on my own and I also replaced all of my code with what you provided and it is currently acting the same way. As a result of my code as well as your that you provided the footer setting field looks like the image below when information is put into the designated area.
  4. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check your issue.
  5. kennykfromthebay
    kennykfromthebay New Member
    USA
    Can you please share the solution to the above problem? I have had the same experience when I tried to add a mailto: link in the bottom footer. It showed up once then mysteriously disappeared. It too, showed up outside the input box in the theme customization page.
    Thanks.
  6. Gourav
    Go to functions > theme-option.php present in your theme directory and replace current code
    text
    with
    textarea
    Check image for reference
    Gourav Shrivastava
  7. Piyush
