Is it me? Just added a review with a 5 star rating on a listing with no previous review/star ratings and having approved the review it shows as a listing with 3 stars and the review itself has no stars at all. I've just updated to the latest theme version 1.8.1 in the hope it would fix this issue but it seems not. Any ideas anyone? Roger B
Hello Roger, I have checked your site and found a listing which contain 5 stars with a review. http://www.eastnorthantsguide.co.uk...-fascia-soffits-cladding-in-northamptonshire/ And also checked theme at my side but not found any review problem. Please do let me know in which listing or any particular case you are getting this problem. So that i can help you. Thanks & Regards Nitesh Raghuwanshi
Thanks Nitesh, Several older listing have a review where the star rating is OK. Try these listings - your admin login to my site is still intact by the way! http://www.eastnorthantsguide.co.uk/listing/mughal-dynasty-inspired-indian-cuisine/ http://www.eastnorthantsguide.co.uk/listing/c-potter-high-class-butchers/ Both had a 5 star review and both have a different star rating on the review and on the listing itself. Roger B
Is there any progress on this as I'm getting users adding reviews and its causing an issue with the ratings showing incorrectly.
