I'm working on updating my website using Startpoint (been working on and off over the past couple of months). I'm trying to delete the menu in the footer. I went through some threads and saw where someone had the same problem. I entered the code suggested in the Styling Options box, but it didn't work. Can you help? Thanks.
In the menu area just build a new menu with no items in it. then select that menu for the footer area
Hello, Greetings from InkThemes! You can also use the below CSS code in Custom CSS field (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard to remove that footer menu. Code: .footer-menu.nav-collapse { display: none; } Hope it will also work... Thanks & Regards! Priyanka Inkthemes.com
