State Custom Field shouldn't be "required"
Discussion in 'ClassiCraft WordPress Theme' started by tshuguenin, Apr 1, 2013.
  1. tshuguenin
    tshuguenin New Member
    State custom field should't be required.
    There are a lot of countries not using the notion of states.
    Go to
    Settings > Custom Field
    and click the edit option of field and set it not required.
    Check image for reference
  3. tshuguenin
    Sorry!! This is not what I meant. apologize! Let me reword this.
    States shouldn't display for countries that have no such things as states.
    Right now, if you create an ad and chose a country such as Germany, France or Switzerland for instance where states do not exist, the state field will still display even though it's not required. So I added the notion of "none" or "n/a" in the selectable list but it would be much better if the states field would display only when needed.
    Thx.
  4. Gourav
    We will try to add this feature in future updates and inform you after such update.
