Static text box.
Discussion in 'Andrina WordPress Theme' started by mferrell6002, Jan 21, 2013.
  1. mferrell6002
    mferrell6002 New Member
    I tried following instruction of thread below. I now have no second picture on slide, but the text box is there.
    hydroshale.com
    here is the code:
    jQuery(function(){
    jQuery('#slides').slides({
    preload: true,
    preloadImage: 'images/loading.gif',
    autoHeight: false,
    effect: 'fade',
    container: 'slides_container',
    play: 6000,
    slideSpeed: 700,
    fadeSpeed: 650,
    crossfade: true,
    hoverPause: true,
    "pause":3500,
    animationStart: function(current){
    if (window.console && console.log) {
    // example return of current slide number
    console.log('animationStart on slide: ', current);
    animationComplete: function(current){
    jQuery('.caption').animate({
    bottom:30
    },300);
    console.log('animationComplete on slide: ', current);
    slidesLoaded: function() {
    bottom:30
    },300);
  2. mferrell6002
    resolved the picture issue, just can not get the text box to be static
  3. Nitesh
    We are not getting your issue, Please explain it little more.
    Note:- We have checked your site. Images you have uploaded in slider and featured area are too big. Add recommended size images.
  4. mferrell6002
    Nitesh, I decided just to remove text box all together. I should have canceled this post. My apologies.
