Still need help with Javascript
Discussion in 'Andrina WordPress Theme' started by vickie, Sep 29, 2015.
  1. vickie
    vickie New Member
    Hi I still need some help. I have some script that the Better business bureau sent to install on our website and I would like it installed in the 3rd widget colum on the right hand side of the footer. I asked for help before but my thread is now locked so I can't respond to it but I am still in need of the help.
    thank you
    I am so sorry for that....
    Please follow the screenshot given below to write your code in the footer section.
    Also, I am providing you a video to display the image over there, please have a look..
    Link of the video: http://screenpresso.com/=e0Kod
  3. vickie
    vickie New Member
    Thanks for responding Priya. However the BBB seal doesnt fall in the third footer even though I installed the script there like you said. It is outside of the footer on the right hand bottom. Not sure what to do.
    Could you please send us your dashboard details at [email protected] along with the seal and code as well?
    We will resolve that, there must be some CSS and HTML issue with that....
  5. vickie
    vickie New Member
    Ok will do that. Thank you
