Strange link behavior in frontage
Discussion in 'RoadFighter WordPress Theme' started by resielaro, Nov 27, 2013.
  1. resielaro
    resielaro New Member
  3. resielaro
    Thanks for sending the link but after some effort with my provider I can't be granted with a rewrite the httaccess file. So that won't' work for me.
    I installed the theme.zip on my local test (MAMP) environment and it seems
    that the same error occurs there too. Only worse, now it will only accept the same link on all three boxes to behave accordingly. If I use any other link to another (published) page, it will result in the same error with the strange string.
    Instead of having a work around provided in php? I start to wonder if the theme.zip file is okay?
    Since it shows the same errors on two different servers now.
    I subscribed recently as a full member to have access to all themes and got the zip-file from the member library.
    If nobody else is facing this problem, could it be that my zip.file is incorrect??
    Hope you can help
  4. resielaro
    Hello again,
    I stumbled on the solution! When comparing the two "Live-site" and "test-site" I looked at the WP versions. My test site is WP 3.5.1 My Live site the current latest version.
    On my Live-site it mentions on every page in the Edit-mode [get short link], when pressing on this, you get another url, short link. I did not pressed OK but instead copied the link, which ends differently in /p ID
    and paste it in the 3rd box link url (theme-options).
    Tried it again and :) it worked!
    On my test-site however (WP 3.5.1.) it does not give the option to [get short link] so that is why I was running into trouble there too.
    Hope my explanation helps others who are facing the same issue?!
    Resie
