Styling Options
Discussion in 'NewCommerce WordPress Theme' started by riviera, Dec 24, 2015.
  1. riviera
    riviera New Member
    How do I add another color to the styling options? What is the CSS to use?
    To add more colors in styling option will require a lot of customization in source code of the theme.
    So it would be better to suggest us the color and area where you want to change color and we will provide you CSS code accordingly and you can easily use that code to change color for your desired area.
    Hope you will understand.
  3. riviera
    riviera New Member
    Hi Priyanka,
    I want to change all areas that are affected by Styling Options to be #427BFF (blue).
    Thanks.
    OK!!
    Please send us your dashboard credentials at [email protected] along with this thread link as well and we will add that color in your styling option.
  5. riviera
    riviera New Member
    OK - have emailed details.
  6. priya
    Thanks for the details..
  7. priya
    Hello Dave,
    You would be glad to know that we have added blue (#427BFF) color in your styling options as per your requirement.
    Kindly check and reply..
  8. riviera
    riviera New Member
    That's great. Many thanks.
  9. priya
    You're welcome...
