I have a problem with the sub menu drop down buttons not clicking on a Samsung Tab 4 tablet device. The sub menu buttons display correctly but when I press them they do not respond. The top level buttons work correctly. The problem is just with the sub menu buttons. Any ideas? Many thanks George
Hello, I have checked your website in iPad and it's working perfectly. There is no problem like you mention above. Thanks & Regards Yogesh Bhade
Hi Many thanks for checking. that was my old that you have the address for. My new site is http://thaispa.cathayinternetmedia.com I do not have iPad to check with. I only have Samsung tablet. However, if the site is working OK on iPad then it might just be a "Samsung thing" - or it could be because I have used a few plugins including a new appointment plugin. Thanks for your help. George
