Subdomain or Subfolder?
Discussion in 'General InkThemes Discussion and Feedback' started by joeaquilina, Jul 3, 2013.
  1. joeaquilina
    joeaquilina Member
    So far i have used the Colorway Theme to create www.clubclass.it which is a site in Italian for our language schools in Malta and London. I now need to create another site using the same theme for Switzerland using the domain www.clubclass.ch , however in Switzerland they have three official languages being Italian, German and French. My questions are the following:
    1. shall i opt for www.it.clubclass.ch , www.de.clubclass.ch, www.fr.clubclass.ch or www.clubclass.ch/it, www.clubclass.ch/de, www.clubclass.ch/fr for the different languages targeting the same country. The extensive research i have carried out so far is pointing towards a sub folder solution, even for SEO purposes - but i would just like a confirmation.
    2. will i need a multilingual plug-in for an one of the above solutions? Any suggestions?
    Thanks.
    Yes, You can use multi language plug-in (qTranslate plugin) for it. It will provide you language changing option for multiple languages in a same domain.
    Download it from the link given below.
    http://wordpress.org/plugins/qtranslate/
  3. joeaquilina
    joeaquilina Member
    Thanks for your reply but my question was - should I opt for a subfolder setup or a subdirectory setup?
    I think that i have found a solution to the above question which was sent to you earlier on today!!
    I have searched the net and i am little bit concerned about qTranslate - it seems that it is no longer being supported by its developer and people are moving to WPML (in fact there is a migration tool for such a move, too). Is there a reason why you suggested qTranslate? WPML seems to be the plugin for multilingual sites. Does the WPML plugin now work well with the Colorway Theme, because until a few months ago there were some issues to integrate WPML and the Colorway Theme?
    I look forward to hearing from you with your comments.
    Joe
  4. Nitesh
    Hello Joe,
    Yes "Colorway theme" is compatible with WPML also. You can use it.
