Submenu background color.
Discussion in 'BizWay WordPress Theme' started by suryapraktijk, Feb 7, 2016.
  1. suryapraktijk
    suryapraktijk Member
    Tilburg, Netherlands
    Hi, How do I change the color if de submenu background to black and the letters to white? It is grey and red now. See the screenshot. Thank you for help.
    With kind regards,
    Margaret.
    Hello Margaret,
    #menu .ddsmoothmenu li li {
        color: white;
        background: black;
    #menu .ddsmoothmenu li li a {
        color: white !important;
    suryapraktijk likes this.
  3. suryapraktijk
    Hoi Priyanka,
    Thank you very much for your quick response to my treat. I use your solution and it work perfectly! I even change the background color to dimgray, because it fits the team beter.
    With kind regards,
    Margaret
    You're welcome Margaret..
