Submit Button for Lead Capture
Discussion in 'Infoway WordPress Theme' started by cjackson, Jan 29, 2014.
  1. cjackson
    cjackson New Member
    I get that I can change the submit button if I update the image file for this, but how can I easily change this so that I can update the text and change the background color instead of replacing the button image?
    Paste this code in Custom CSS
     .signupForm .signinForm input[type="submit"]{
    background:red;
    border-radius:4px;
    .signupForm .signinForm input[type="submit"]:hover{
    background:red;
    opacity:.8;
    Gourav Shrivastava
  3. jjelinek
    jjelinek New Member
    Thanks for this. How can I change the text that says "Send Your Message" on the submit button?
  4. Piyush
    For this go to the
    Theme directory > functions > infoway_front.php
    And change it from there.
    This will fulfill your requirement.
  5. jjelinek
    jjelinek New Member
    Thanks, I figured it out by grepping for "Send Your Message" recursively and found out where to change it. I appreciate your help though!
  6. cjackson
    cjackson New Member
    All very helpful, but this did not fix the form format on the secondary pages where the form appears in a widget - how can I update that - form both the text and the background color?
  7. Piyush
    .signupForm .heading {
    background: black;
    color: red;
    .signupForm {
    background: red;
    In place "black" and "red" you can put your color or color code.
