Subscribely Membership Question
Discussion in 'Subscribely v2 WordPress Theme' started by egnalc, Jul 10, 2013.
  1. egnalc
    egnalc New Member
    Hi
    I have a client that may be purchasing the template but I have a few questions.
    Can they import a current membership list from another site?
    Is there a Search feature available?
    Can the templete colors be customized?
    Is there an additional charge for the membership feature?
    Charlie
    Here are the replies to your queries.
    1. No you can't import a membership list from another site.
    2. Yes, search feature is there in the theme.
    3. Yes, that would be possible too.
    4. No, there is no additional charge for the membership. It depends on your choice how you decide the price of membership.
    I hope this will clarify your doubts. All the best for making a good website.
  3. sooraj
    sooraj Member
    India
    Dear sir
    Can i create profile page for paid members? After display the profile want to go view the contents is it possible ?
  4. Gourav
