Hi, Might it be possible to substitute the navigation menu in Figero with the standard menu in, for example, your BizWay theme? Thanks, Rex
Hello, Our all themes are uniquely designed and they have their individual unique features. So, it is not possible for us to interchange their menus unless you custom code something. Sorry. If this isn't something you're able to do then you would need to hire a freelancer for this.
