symmetrical post snippets
Discussion in 'ButterBelly WordPress Theme' started by vesity, Aug 15, 2014.
  1. vesity
    vesity Member
  2. Yogesh
    Yogesh Guest
    Add these lines in functions.php file as shown in screenshot.
    // for excerpt
    function custom_excerpt_length( $length ) {
            return 50;
        add_filter( 'excerpt_length', 'custom_excerpt_length', 999 );
    Yogesh Bhade
  3. vesity
    vesity Member
    Thanks for your reply; unfortunately, it does not completely fix the problem, although it helps. At "return 50" it showed no difference in my test posts, so I set it to "return 40." You can see that now the first two posts snippets are equal in size with 3 lines of text, but the 3 post has 4 lines of text. (http://www.tiffanynesbitt.com). I tried other return amounts as well, 15, 20, 30, etc., but the posts were still inconsistent.
  4. PankajK
    PankajK Support Staff
    Hi vesity
    Unfortunately there is no way to limit the excerpt by line. But you can use some trick.
    1. The first thing you need to do is to add this code to your functions.php file
    PHP:
    function custom_excerpt_length$length ) {
            return
    40;
    add_filter'excerpt_length''custom_excerpt_length'999 );
    2. Now if you still find a post which has more lines, then edit your post and make you excerpt even shorter with "Insert Read More Tag Button".
  5. vesity
    vesity Member
    Got it - excellent - thank you!
