Tagline in Footer is too dark
Discussion in 'BlackBird WordPress Theme' started by dubloon2, Oct 28, 2015.
  1. dubloon2
    dubloon2 Member
    At the very bottom of my website: http://www.howecpa.com/
    The Tagline: Smith-Garner, PC - Accountancy Professional Corporation
    is too dark. Can I specify to use White text?
    Don
    Hello Don,
    .footer_bottom .footer_bottom_inner span.blog-desc {
        color: white !important;
  3. dubloon2
    dubloon2 Member
    Thanks Priyanka,
    That fixed it great. Can I do the same for the Copyright clause on the right? What is the syntax for that?
    Thanks!
    Don
    Hello Don,
    To change the color of Copyright text, you just need to paste the code given below in Custom CSS section of your dashboard.
    .footer_bottom .footer_bottom_inner span.copyright {
  5. lionsden
    lionsden New Member
    How do I reduce the font size in the actual footer not footer widgets?
  6. priya
    .footer_bottom_inner {
        font-size: 15px;
    Change numeric value as per your requirement..
