Tap to call button translation
Discussion in 'Traffica WordPress Theme' started by lowcostweb, Oct 15, 2013.
  1. lowcostweb
    lowcostweb New Member
    Dear support,
    I like to translate the "Tap to Call" button on the front page from Traffica Pro Theme into Dutch.
    Can you please tell me where I can do this translation?
    Kind regards,
    Dennis
    It is not possible to translate the text of "Tap to Call" button because it is an image not a text. If you want to change its text then, Go to images directory present in your theme directory and replace your image with present "tap-to-call.png" image or edit it.
    The name of image is
    1."tap-to-call.png"
