Tap to call button
Discussion in 'Appointway WordPress Theme' started by pauljw, Apr 2, 2021.
  1. pauljw
    pauljw Member
    I am trying to get my site ready for the new Google requirements.
    It's going well but I have a problem with accessibility, the score is low because it looks like the tap to call button needs a Name or something.
    I have attached a screen shot of the issue.
    The web site is:
    https://www.doncastercarpetcleaners.co.uk/
    The site I am using for the test is:
    https://web.dev/measure/
    If you have a piece of code that I can put in the header or something that would be good.
    Paul.
  2. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    Thanks for sharing the details with us here.
    Let me know what kind of name you want for the tap to call button?
    So that we can provide you with the solution here.
    Shemaela
  3. pauljw
    pauljw Member
    Lighthouse report 11th April 2021.png Hi Shemaela,
    The name on the tap to call button shows as 'tap to call'.
    This is fine for me.
    However, when I run the lighthouse test, I get this message:
    Links do not have a discernible name
    So I think it must be something to do with the link? Not the text on the button.
    The lighthouse test says this:
    Link text (and alternate text for images, when used as links) that is discernible, unique, and focusable improves the navigation experience for screen reader users.
    Failing Elements
    div.grid_10 > div.call-us > a.btn" data-path="1,HTML,1,BODY,0,DIV,0,DIV,0,DIV,0,DIV,1,DIV,0,DIV,3,A" data-selector="div.header > div.grid_10 > div.call-us > a.btn" data-snippet="" style="box-sizing: border-box; -webkit-font-smoothing: antialiased;">
    a
    <a href="tel:07544880558" class="btn lazyloaded">
  4. shemaela21
    We have forwarded your support request to our technical team they will first check it and will let you know about it.
    Kindly be patient until we get back to you.
    Shemaela
  5. pauljw
    pauljw Member
  6. shemaela21
