Tap to call number no saving
Discussion in 'Local Business WordPress Theme' started by guavaguy, Apr 11, 2014.
  1. guavaguy
    guavaguy New Member
    Aloha,
    I have been trying to change the tap to call number for the mobile view on Local Business.
    I go to Theme Options>General and enter the number as xxx-xxx-xxxx ( using real numbers) however, it does not save after clicking update options. It will SAY it saved, but it does not. When I got to the site on an iphone, I still get t he (555) 123-4567 number showing.
    The site is www.absolutemarbleandtile.com
    Thank you for your help.
    Go to
    Appearance > Theme Option > General Settings > Top Right Contact Details
    and add your contact details there.
    Gourav Shrivastava
  3. guavaguy
    guavaguy New Member
    Gourav, thank you for that...howere it does not change anything....would it be be cause I am using a custom header?
  4. Piyush
  5. guavaguy
    guavaguy New Member
    Thank you Piyush. Updating solved the problem. Thank you everyone for your help and your time.
