Template is not Working
Discussion in 'GeoCraft WordPress Theme' started by trentmunday, Sep 28, 2013.
  1. trentmunday
    trentmunday New Member
    Hi!
    One of my user just informed me that my site template is not working properly when he is searching for ads via search box...
    I tested it myself and found out that the template is not functioning properly... for ref: please click on the below link to check it
    http://myuniads.com.my/search/?pn=2&sfrom=room&location=
    Please help me fix the issue asap otherwise it will effect my site because we have just started our marketing campaign on FB
    The problem is not only with my template you check your site template as well DEMO geocraft it's not functioning well: http://www.98london.com/search/?pn=2&sfrom=&location=london
    Your side bar goes automatically underneath the listing in footer.
    TQ!
    Download updated version of theme from your members area and upload it.
    Login here: http://inkthemes.com/members/member/index
    Thanks for informing us we will update our Geocraft theme demo.
  3. trentmunday
    Hi!
    Thanks for the reply... But I have did too many customization in the existing version even I have paid InkThemes to do few customization... If I will simply upload the new version of theme it will override the old custimizations and it's again going to cost me money and time.
    Please help me out with this and let me know the why by which I can easily update the theme with lossing my old customized options.
    TQ!
  4. Gourav
    For this you can use child theme
    Just copy your edited files and paste it in the childtheme directory.
    Then activate child theme. Your site will look same as it is while main theme was activated.
    After that update your theme version
    Your edited files which you have added in the child theme directory will remain intact.
    Only main theme files will update or change after updation.
    Also follow link given below for child theme detail.
    http://www.inkthemes.com/httpwww-in...rdpress-a-way-to-save-themes-modification/02/
    Note:- Child theme only support parent directory files, Do not add sub directory files in child theme.
  5. trentmunday
    Hi...
    But i have no idea what are the files you guys have edited in my theme if you can just mail me that where and what code i need to put if i want to remove the discription and add price area instead in add preview.
    Tq!
  6. Nitesh
    Support mail sent.
  7. trentmunday
    Thanks for the great support... There is an minor issue
    In search result it's showing comment off... as I can see in update log it's say that comment off issue is fixed in search result but it's doesn't seem so.
    TQ
