Hi, I just installed theme and was attempting to update the testimonial area and notice there is only one input area and none for the picture etc. Please help. Than you, Ben
Hello Ben, Thanks for reaching out us, It should work, Can I have your site URL and some screenshots of the concerned areas of your website. I will check and let you know the exact solution. Regards! Naveen Kolhe InkThemes.com
Kindly, share your WordPress admin credentials at [email protected] along with this thread URL: WordPress site login URL: WordPress admin username: WordPress admin password: We will check and do the needful. Warm Regards! Naveen Kolhe InkThemes.com
I emailed the credentials to you all. With the subject matter: WordPress admin (Testimonial and Booking section not showing)
Hello, We looked into the issue and found that your testimonial posts were not published, you must have published them to display on your site. Please check your Dashboard->Testimonials section from the backend of your site. Regards! Naveen Kolhe InkThemes.com
