Testimonial Images
Discussion in 'BlackWell-WordPress Business Theme.' started by vesity, Sep 21, 2014.
  1. vesity
    vesity Member
  2. Yogesh
    Yogesh Guest
    Your issue have been fixed. Please check.
    Yogesh Bhade
  3. vesity
    vesity Member
    Thank you. Can you show me how I can add the images? Which theme files need to be edited, and how do I add image? Thanks.
  4. Yogesh
    Yogesh Guest
    Hello Vesity,
    This problem is solved in latest version of blackwell theme.
    If you don't want to update your theme, you have to set images for all three newly added testimonial section as shown below in screenshot.
    It will resolve your issue.
    Yogesh Bhade
  5. vesity
    vesity Member
    Thank you!
    When you say "This problem is solved in latest version of blackwell theme"...
    Do you mean that it now accommodates 6 testimonials right there in Theme Options?
    If so, do you suggest I create a child theme and install new update?
    What are the instructions for updating theme?
  6. Yogesh
    Yogesh Guest
  7. vesity
    vesity Member
    Hi. Please help. I followed the instructions... I created a child theme, which worked perfectly. Then I updated the theme to the latest version, 1.2. But much of the work I'd done (customizations) did not make it, including these items: (I've included the link to the original support request for each item):
    1. The panel now defaults out instead of in. (http://www.inkthemes.com/community/threads/menu-panel-default-to-in-not-out.13502/)
    2. Testimonials section is moved back to the default position instead of where we moved it. (http://www.inkthemes.com/community/threads/change-order-of-features.13813/)
    3. All the work we did to customize the blog excerpts is gone, such as...
    A. character count controls are gone (http://www.inkthemes.com/community/threads/post-excerpt-problem.13854/#post-51775)
    B. Moving items, such as date, author, and adding category, all gone. (http://www.inkthemes.com/community/threads/make-changes-to-posts-on-homepage.13855/#post-51739)
    ...and other problems. ( I don't care about losing the customizations to the testimonials section, because your update goes beyond that.)
    Thankfully, I had saved a copy of the original theme, so I reloaded it to get all my customizations back. So if you look at the theme the way it is now... with the changes to layout, post excerpts, menu panel, etc... those all must be kept. But I do want to update to 1.2 so I can get the changes you made to the testimonials section. Can you help update without losing all those customizations? I will send an email with WP credentials and cPanel credentials. Thank you!
  8. Yogesh
    Yogesh Guest
    Hello Vesity,
    We provide one time customization to the customers and told them not to update your theme, If some one find it is essential to update the theme then we will charge 25$ per hour for the same customization.
    The customization you have right now is time taking one and therefore, we will charge for this.
    Do you agree? If so then we will tell you about the payment details.
    Yogesh Bhade
  9. vesity
    vesity Member
    Hi.
    I've purchased many themes from you, and plan to purchase more, but I have never been asked to NOT update a theme. And I never asked for you to do customizations -- I just asked for instructions, and you sometimes volunteered to do the customizations yourselves. For that I'm very grateful, but it seems strange to me that I'm now being penalized for wanting to update.
    I tried to do it myself... I was very careful to follow your instructions and create a child theme and then update the theme, but it did not work. One of the most important features to me is testimonials -- and it is now significantly expanded. Yet it is not available to me without the update. Since I cannot update without messing up site, I'll just have to do it and then go back to each item again, one-by-one, and try to figure it out.
    I am always referring others to your site because I think you are a good company with good themes and great customer service. But in this case, I do not feel like it is a fair judgement.
    Thank you,
    Chris​
  10. Yogesh
    Yogesh Guest
    Hello Vesity,
    I have created a child theme, use following file as child theme that file contain your customisation, and you can update your theme.
    Update your theme without lost your customisation. Cheers
    Yogesh Bhade
  11. vesity
    vesity Member
    Thanks so much for doing that! Unfortunately, it doesn't work. After installing it and then activating it in dashboard, everything went blank -- my WP dashboard would not show up at all. I hit the browser BACK button and then manually deleted the file in order to get back to my regular theme. I looked at the files in the child theme and could not find obvious reason why it doesn't work.
  12. Yogesh
    Yogesh Guest
    Hello Vesity,
    I will try it on your site.
    Yogesh Bhade
  13. vesity
    vesity Member
    Did you try it?
  14. Yogesh
    Yogesh Guest
    No, but today i will try it.
    Yogesh Bhade
  15. Yogesh
    Yogesh Guest
    Hello Vesity,
    I have tried to activate child theme but after installing it and then activating it in dashboard, everything went blank. so please recover it as you did before and send us your FTP details at [email protected] to solve this child theme issue.
    Yogesh Bhade
  16. vesity
    vesity Member
    I have sent email with cpanel credentials and backup file
  17. vesity
    vesity Member
    I have fixed the site, and restored it back to how it was. The child theme you installed is still in the folder.
  18. Yogesh
    Yogesh Guest
    Hello Vesity,
    I have fixed your issue.
    Yogesh Bhade
  19. vesity
    vesity Member
  20. Yogesh
    Yogesh Guest
    Hello Vesity,
    Now don't change in parent theme, you have to change in child theme.
    Just copy that file which you have to edit, and paste it in child theme then edit that file in child theme.
    Always use this process.
    Yogesh Bhade
