Testimonial Section
Discussion in 'Dzonia WordPress Theme' started by 1stopnonprofitshop, Mar 26, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Are you only allowed a certain amount of characters in the rotating testimonial section? Part of my text is getting cut off at the end, so wondering if that's why.
  2. nitin
    nitin Guest
    I would like to let you know that as such there is no limit over the content you enter in the testimonial section.
    If you are facing the issue of text getting cut-off, to determine and fix the issue, we need access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password :
    We will try to do the changes ASAP.
    Nitin
