Testimonial - Slider
Discussion in 'Infoway WordPress Theme' started by profilewingman, Nov 25, 2013.
  1. profilewingman
    profilewingman New Member
    Hello! Is there any way to make my testimonials into a slider. We have received some very nice feedback from clients and don't want the testimonial section to be stagnant. Would love the testimonial part on the bottom of our page to slide so we can put several on. Would be nice to keep them rotating every 10 seconds.
    THANKS!
    www.profilewingman.com
    There are multiple testimonial plugin at the WordPress.org. You can pick any one of them.
    And add testimonial at the footer widget area.
    Nitesh Raghuwanshi
  3. profilewingman
    I am hoping that I can put it on to your Ink Themes page so it is seamless. I am trying to add a testimonial but it won't just show up on the homepage… Any thoughts?
  4. Piyush
    Unfortunately there isn't a way to do that with this theme unless you custom code something up. Sorry.
    Or
    You can search more plugin on WordPress.org that will fulfill your requirement.
