Text box - Andrina
Discussion in 'Andrina WordPress Theme' started by sspore520, Jul 15, 2013.
  1. sspore520
    sspore520 New Member
    1.)How do I remove the text box on a specific slider?
    2.)How do I change the background color of the text box on a specific slider?
    It is not possible to remove or change the color of any specific textbox on the slider, If you want to remove the text box then it will remove the textbox from all of the slide images and it is same for color also.
