Text color background
Discussion in 'BizWay WordPress Theme' started by prime369, Jan 26, 2013.
  1. prime369
    prime369 New Member
    I changed the background and now the text background is white. here's a snapshot of my problem:[​IMG] eeLEW.png
    Also, as you can see I have changed the color of my menu bar. I would also like to change the color of the "submit" button in the contact page to match the color of the menu bar. Here's a snapshot:
    Thanks.
  2. Harmeet
    Harmeet Support Staff
    That is the image of the button which is used in the contact form. In order to change the color you have to make changes in the image.
    You will get the image in "images" directory of your theme. You can edit the image using any photo editing tool and replace it with the previous one it will change the color of your contact form button.
