Hello, Please paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: ul.single li p { margin-bottom: 5px !important; } Thanks, Praveen
Thank you. This helps with the look however when I edit it to make spaces between lines (where I want them), it wont' update as such.
Hello, Kristin! Please paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: ul.single li p { line-height: 2 !important; } Thanks, Praveen
Sorry- still not displaying correctly. For example, if I create a bold title with text below and then space followed by another bold title with text, there is no line spacing showing up still.
Any help here? I am having trouble with my blog posts looking professional as there are limited options to edit like you would in a word document. My images have text lining up right next to them and I can't adjust. And this line spacing issue as well as not being able to adjust the font size in places. This is probably due to my lack of coding knowledge but any help would be appreciated. Thanks.
Hello, Kristin! Don't worry about your coding skill, we are here to assist you. Where do you want to show the text next to the images? As far as the line spacing issue is concerned, create some edited screenshot showing the exact view that you exactly want and provide us. We will assist you to adjust the line spacing. Thanks, Praveen
