Text not formatting in Hours box
Discussion in 'Appointway WordPress Theme' started by pixvault, Jan 21, 2014.
  1. pixvault
    pixvault Member
    No matter what I try I cannot get the text in the Hours box to format correctly.
    As you can see from the attached image the line break is not in the correct place.
    It should look like
    Days: Mon - Sun
    Winter: 10am - 4pm
    Summer: 10am - 7pm
    How do I fix this?
    You can use line break tag (i.e <br> tag ) to break the text in a next line.
    Go to the Appearance > Theme Options > Home Page Feature Sidebar panel in your dashboard
    and paste the text like given below in the Timing Description setion.
    Days: Mon - Sun <br>
    Winter: 10am - 4pm<br>
    Summer: 10am - 7pm
  3. pixvault
    pixvault Member
    Many thanks for the swift response Piyush :)
    I wasn't aware that I could use html tags in the backend, (apart from the text editor in a page) as most other themes I've used tend to show the tags. Problem now solved
    I have to say, the support from inkythemes is way better than I've experienced with other themes I've purchased elsewhere :D
