text not showing up on home page
Discussion in 'Woodpecker WordPress Business Theme' started by sandradohn, Dec 14, 2015.
  1. sandradohn
    sandradohn Member
    Hi There, I have added text to the 3 column area on the home page and it does not show up. Please advise. The website address is breakthroughppc.com
    Thanks, Sandra
    Hello Sandra,
    I have checked your site and would like to tell you that we didn't find any issue in your site, all the descriptions showing perfectly over there.
    Kindly check..
  3. sandradohn
    sandradohn Member
    Hi There, It is the heading. I have attached a screen shot. I also cked it on several different pcs and my ipad with the same result. Please advise. Thanks, Sandra
    Would you please let me know what you have added in Theme option panel of your dashboard through the screenshot.
  5. sandradohn
    sandradohn Member
    Hi There, Here is a screen shot of the text that I keep re entering... It keeps erasing itself and not showing up on the website. Thanks, Sandra
  6. priya
    Hello Sandra,
    Could you please send us your dashboard details at [email protected] along with this thread link as well so that we can figure out the issue and able to resolve that.
