Text Problems
Discussion in 'ColorWay WordPress Theme' started by tundratech, Nov 10, 2013.
  1. tundratech
    tundratech New Member
    I just upgraded to the Pro version of of Colorway.
    All I wanted was the slider and the gallery features. Unfortunately Text is changed within the Pro version.
    The Header Text is different and I really want the Non Pro text. How do I do this?
    One other thing that is odd--
    When I activate the Pro version, it changes the text within my Wordpress Dashboard. If I activate the Pro Version, all text gets bigger. Basically all I do to replicate this is to activate the theme and go to the dashboard. Then go back to activate the Pro them and back to the dashboard. I need to fix this as it is hard to manage other plugins etc with text in different sizes.
    I have enclosed screenshots the text issue and also of the dashboard issue.
    Go to js > custom.js present in your theme directory and
    remove the code given below
    //Cufon replacement
    Cufon.replace('h1')('h2')('h3')('h4')('h5')('h6');
    This will solve your issue
