Text verry close to picture / CSS does not work
Discussion in 'Compass WordPress Theme' started by kreyenhop, Jan 9, 2015.
  1. kreyenhop
    kreyenhop New Member
    Worpswede Germany
    I have this coding within the CSS section. The spacer to the picture does not work. Can you help please?
    body {
    background: #F2F2E5;
    .page_content .content_bar .post.single .post_content img {
    padding: 15px;
    Sven
  2. praveen
    praveen Support Staff
    Hi kreyenhop,
    Please provide us url of your website.
    With some edited screenshots of the areas where you are encountering issues.
    Praveen
  3. kreyenhop
    Worpswede Germany
  4. Pramod
    Pramod Guest
    Hello Sven !
    I have fixed this issue please have a look.
    .page_content .content_bar img {
    padding: 15px;
    this code works.
    Pramod
  5. andreahw16
    andreahw16 Guest
    Wheaton, IL
  6. priya
    Hello Andrea,
    Would you please try this code given below in Custom CSS field of your dashboard and check after that.
    .su-column {
        margin-top: -25px !important;
    Change numeric value as per your requirement.
  7. andreahw16
    andreahw16 Guest
    Wheaton, IL
    I am sorry that did not work. I have other code here that is in my css styles but for some reason this is not worrking, other code is
    padding: 20px;
    } which is working with posts. Should I remove code that changes nothing?
    Hope to get this resolved, it is so ugly to have no padding around images.
    http://www.grandmamauds.com/retail/bean-meals-2/
    Thank you
    Andrea
  8. priya
    Hello Andrea,
    Sure, you can remove all the code which are not working for your site.
    And to create padding around the image, would you please try below code for once..
    a img.alignleft {
        padding: 10px;
  9. andreahw16
    andreahw16 Guest
    Wheaton, IL
    This did help better, it is changing padding all around the image and not just on the right. It definitely looks better though and will try to work with it, thank you. Attaching a screen shot so you can see the extra left and top is off. It should flush left and top of image align with copy. It is close though.
    Thank you for your patience in getting this fixed.
  10. priya
    Hello Andrea,
    Hope below code will help you to meet your exact requirement..
    a img.alignleft {
        padding-right: 20px;
