When I sent name, phone number, and email. It used to work on september 22nd. Now, somehow it's not working. Maybe it's due to update in the theme. Let me know if the new update has any issues. http://speedycarloans.ca/ Albert
Hello, Make Lead Capture Settings from your dashboard(theme option). If issue is still then download a fresh copy of theme from your member area and make its settings to receive leads. Thanks & Regards Pramod
Could it be the server problem? I have Naveen who has left the form today. I believe it's from you guys. However, I have not been able to get the form sent to my Leads Capture page. I'll try to a fresh copy.
Fresh copy does not work either. I also tried disabling all the plug-ins to see if plugins are affecting the form. I even tried older version of the theme that used to work, and still does not work. http://speedycarloans.ca/
We have got your concern, please send us your WordPress dashboard admin login details at [email protected]. so that, we can have a look over the issues in detail and will try to resolve them. Your website Login link: WordPress username: WordPress password: Note: Once your issue get resolved, you can change your password. Thanks & Regards InkThemes.com
I have sent the username and password to the email. Could you let me know if the lead capture is being fixed? Thanks in advance, Albert
Hello ronaldsinai, If you can install a fresh copy of theme ? Do this because we have checked theme many time and it does not have this issue. May be any plugin creating problem or your hosting does not allow you to send message. Thanks & Regards Pramod
