The slideshow does not work
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by matlars, Jan 19, 2015.
  1. matlars
    matlars Member
    WordPress 4.1
    Retrieved theme 19 / 1-2015
    The slideshow will stop at the first picture, you can not browse image. Something wrong?
  2. Pramod
    Pramod Guest
    Hello !
    We have checked theme and it works correctly.
    Please add images on slider properly from theme options.
    Please re-install the theme if issue does not fix.
    Pramod
  3. klickdesign
    klickdesign Guest
    I have also reinstalled and found the slider is not working.. any help? I did get a notice to upgrade woocommerce.. could that be the problem? And looked into the settings for woocommerce and saw this:
    salejunctiontheme/woocommerce/content-product.php,
    salejunctiontheme/woocommerce/global/sidebar.php version - is out of date. The core version is 1.6.4,
    salejunctiontheme/woocommerce/global/wrapper-end.php version - is out of date. The core version is 1.6.4,
    salejunctiontheme/woocommerce/global/wrapper-start.php version - is out of date. The core version is 1.6.4,
    salejunctiontheme/woocommerce/single-product.php version - is out of date. The core version is 1.6.4
    website is live right now and can be found at veilbridalandformalwear.com (preliminary design stages)
  4. Pramod
    Pramod Guest
    Hello Klickdesign!
    Please upgrade your woocommerce plugin.
    This will resolve your issue.
    Thanks & regards
    Pramod
  5. matlars
    matlars Member
    No, it only show the latest upload! Have allso tried on other domain...
  6. Pramod
    Pramod Guest
    Hello matlars!
    Please explain little bit more about your issue.
    Pramod
