Theme Color
Discussion in 'Squirrel WordPress Theme' started by 1stopnonprofitshop, Mar 24, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Can I change the theme color to a specific color name or number? Depending on the site I'm building, I may want the footer widget area and navigation bar to have a specific color.
  2. nitin
    nitin Guest
    You would be glad to know that YES, it's possible.
    Just let me know the specific color code which you want to change to. Also, provide us URL of your website along with some edited screenshot of your requirements/concerned area.
    We will provide you the necessary CSS code to get the work done.
    Nitin
  3. 1stopnonprofitshop
    The URL is theme2.1stopnonprofitshop.com. I'm attaching screenshots of the areas I would like to change to the specific color. The color code is 7ccaf7.
  4. Naveen
    Hello!
    You need to paste below CSS code in Custom CSS field located in Dashboard->Appearance->Theme Options->Styling Options
    #menu .ddsmoothmenu{
        background: #7ccaf7;
    .footer {
        background-color: #7ccaf7;
        -moz-box-shadow: 0px 1px 6px #424141;
        -webkit-box-shadow: 0px 1px 6px #424141;
        color: #000;
    .footer h1, .footer h2, .footer h3, .footer h4, .footer h5, .footer h6{
        color: #fff;
    This will resolve your issue,
    Warm Regards!
    Naveen Kolhe
  5. 1stopnonprofitshop
    When I change the color of the footer box, you can't see all the text because it blends in. Am I able to change the color of the text in the footer box to black?
  6. priya
    .footer, .footer a, .footer h4 {
        color: black;
