Hello Sir, I just wonder whether it is possible to customized the theme color ? At the moment your red color doesnt seems red like the one you have it at this theme www.yogaforbeginners-kl.com. Its more of pink color. Do advise if possible to adjust the theme color. Thank you.
Hello, You can edit any existing color of the color scheme through the process given below. Firstly, go to the Appearance -> Theme Options -> Styling Options panel in your dashboard and select the pink color scheme from the Theme Stylesheet section. And then go to the Theme directory >css directory> color directory > pink.css file and edit pink.css file as instructed in the image given below. See the link for reference. http://www.inkthemes.com/how-to-edit-internal-files-through-ftp/07/ I hope this will help you.
