Theme issues with Gravity Forms
Discussion in 'BlackBird WordPress Theme' started by davekerfoot, Nov 8, 2015.
  1. davekerfoot
    davekerfoot New Member
    I'm having an issue where my gravity form isn't showing on the website. I get absolutely nothing. When I add 'display:none' to the css it works but some of the functionality isn't there (like the date picker). I have switched the theme to Twenty Fourteen and it works fine so I know that its a conflict with the theme and gravity form states that: Because my form uses conditional logic it has an inline style of display:none applied, if my page has any JavaScript errors they can prevent the Gravity Forms scripts from running, and when those scripts can't run the inline display:none style can't be removed.
    This is the error present on my page:
    custom.js:25 Uncaught ReferenceError: toggleChildren is not defined
    The custom.js file is being included by the theme and I was told to contact the theme developer so they can fix the JavaScript error.. Should I just download the latest theme? I'm using Blackbird Pro Responsive 1.9.5 but I don't see any relevant bug fixes in the newer releases.
    = version:2.1.4
    1. WPML-XML file added to support multiple language translation.
    = version:2.1.3
    1. Unlimited Feature Box Section Add
    = version:2.1.1
    1. Error notification issue fixed.
    2. Dashboard Design Distraction Issue Solve.
    = version:2.1.0
    1. Post meta style issue fixed.
    2. Twitter recent post plugin style issue fixed in sidebar.
    3. Comment showing in password protected post before entering password issue fixed.
    = version:2.0.0
    1. Testimonial Auto hight Problem Fixed.
    = version:1.9.9
    1. RTL Enabled.
    = version:1.9.8
    1. Slider Speed Option Added In Theme option panel.
    = version:1.9.7
    1. Slider Image Increase 4 to 6.
    = version:1.9.6
    1. Mobile View fixed.
    = version:1.9.5
    1.Comment Form Style Fixed.
    2.Slider image loading time issue fixed.
    3.W3c Css and Html Validation Issue Fixed.
    4.blog page peginetion connect.
  2. davekerfoot
  3. priya
    Could you please send us your dashboard credentials at [email protected] along with this thread link so that we can figure out the issue?
