theme not work... Parse error: syntax error.....
Discussion in 'BusinessGrow One Page WordPress Theme' started by matlars, Jan 27, 2015.
  1. matlars
    matlars Member
  2. Pramod
    Pramod Guest
    Hello !
    Delete this theme and deactivate plugins.
    Please download again theme and install it in your dashboard.
    This will resolve your issue.
    Pramod
  3. matlars
    matlars Member
    I have treid but it will be the same! have allso tried on other domain....?
  4. matlars
    matlars Member
    I try on another web host, it works, what can cause the hosting company does not approve this theme and the error message will be?
  5. Pramod
    Pramod Guest
    Hello !
    May be this error is because of server settings or PHP versions.
    We have checked but not found this issue.
    Pramod
  6. matlars
    matlars Member
    which has the theme php requirements and other system requirements?
  7. matlars
    matlars Member
    If I take dynamic-image.php from appointwaytheme and use in this theme starts the theme but they do not look good. so something must be wrong or not to support the ..
  8. Pramod
    Pramod Guest
    Hello !
    Please provide URL of website.
    You can make it correct with the help of CSS.
    Not any specific php version is required.
    It worked on all version.
    If any issue occurred we will help to resolve them.
    Pramod
  9. matlars
    matlars Member
    It gets the same error message for me when I activate the theme Foogo Pro .. never had problems with your themes before..
  10. matlars
    matlars Member
    Its look the dnamic-image.php file crasch when I upload it or something....
  11. matlars
    matlars Member
  12. Pramod
    Pramod Guest
    Hello !
    There is not any issue in the theme.
    It is just because of the code is arrange automatically when you installed on your dashboard and it change the whole syntax which creates these issues.
    Many times line by line code will arranged in single line.
    To manually solve this extract downloaded theme and copy all the code of this file and paste it on your installed theme file.
    Pramod
  13. salusnet
    salusnet New Member
    I have this issue
    Parse error: syntax error, unexpected 'function' (T_FUNCTION) in /home/labsalus/public_html/clinicasyhospitaleslaguna/wp-content/themes/geocrafttheme-v2/library/controls/dynamic-image.php on line 1
    How can I solve this issue?
  14. Pramod
    Pramod Guest
    Hello Salusnet !
    Please download theme from member area and extract it.
    After extract geocrafttheme-v2/library/controls/dynamic-image.php
    copy all content of dynamic-image.php and paste it in the place of your error file code.
    Appearance=>Theme Editor( wp editor plugin)=>library/controls/dynamic-image.php
    Pramod
