Theme update causing site issues with menu and footer
Discussion in 'Andrina WordPress Theme' started by mecmec, Mar 5, 2021.
  1. mecmec
    mecmec New Member
    I have just updated an older Andrina Pro to the new one and there are now issues with the site's homepage:
    Footer missing on the home page but okay on other pages
    Homepage images are gone
    Homepage is pushed to the right of the screen on desktop but other pages are fine
    Site also has issues with the blog roll section on the home page which were there before and partially fixed now.
    Can you offer any ideas on how to fix this? If I should post each issue individually please let me know.
    Site screenshot before:
    https://ibb.co/ZmPJbTg
    Site now:
    https://simcoecarpentry.ca
  2. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    Kindly send the below-mentioned credential details to [email protected].
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will check the issue and will let you know about it.
    Shemaela
  3. mecmec
    mecmec New Member
    I have emailed the details requested, thanks.
  4. mecmec
    mecmec New Member
    Hi, is there any update on the problem above?
  5. shemaela21
    I hope the issues you had with the theme are now resolved.
    Let us know if there is anything else with which we can help you.
    We will be happy to help you.
    Shemaela
  6. mecmec
    mecmec New Member
    No, they aren't solved. I added the images back but when the "Homepage Blog Section" is turned on it shows an error and the footer section does not show and the page is cut off. When this blog section is turned off the footer shows fine but with no errors but also no blog section.
    Warning: file_put_contents(https://simcoecarpentry.ca/wp-content/uploads/2020/06/IMG_2567-scaled-final730.jpg): failed to open stream: HTTP wrapper does not support writeable connections in /var/www/wp-includes/class-wp-image-editor-imagick.php on line 737
    Fatal error: Uncaught Error: Cannot use object of type WP_Error as array in /var/www/wp-content/themes/andrina-pro/includes/dynamic-image.php:271 Stack trace: #0 /var/www/wp-content/themes/andrina-pro/functions.php(947): andrina_thumbnail_resize(981, '', 730, 357, true, 90) #1 /var/www/wp-content/themes/andrina-pro/templates/home-blog.php(56): andrina_get_thumbnail_blog(730, 357) #2 /var/www/wp-includes/template.php(732): require('/var/www/wp-con...') #3 /var/www/wp-includes/template.php(676): load_template('/var/www/wp-con...', false, Array) #4 /var/www/wp-includes/general-template.php(204): locate_template(Array, true, false, Array) #5 /var/www/wp-content/themes/andrina-pro/home.php(38): get_template_part('templates/home', 'blog') #6 /var/www/wp-includes/template-loader.php(106): include('/var/www/wp-con...') #7 /var/www/wp-blog-header.php(19): require_once('/var/www/wp-inc...') #8 /var/www/index.php(17): require('/var/www/wp-blo...') #9 {main} thrown in /var/www/wp-content/themes/andrina-pro/includes/dynamic-image.php on line 271
  7. shemaela21
    Shemaela
  8. mecmec
    mecmec New Member
    I had sent the login details but will send them again. Please note that the error and footer issue only happens when the Homepage Blog Section is activated. Currently it is turned off.
  9. shemaela21
    Okay, we will keep this in mind and kindly share the details along with the thread link.
    Our technical team will further have a look at the issue for you.
    Shemaela
