The footer on this site has suddenly dramatically increase in size and is covering up the two bottom components. https://www.paranormalromancebookauthor.com/ This is the CSS that is in the customization section: .footer .footer_menu { display: none; } Any ideas? Thanks, Don
Hello, Greetings from InkThemes, I didn't quite understand your query properly, will you please elaborate it a bit more with the help of some edited screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution. Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
