Hi! Suddenly the changes that I've done in the "Custom CSS" doesn't work anymore. The code I´ve added is: .content h3 { display: none; } #commentsbox { display: none; } .feature_content h2, .testimonial_wrapper h2 { color: #009DE0; } .read_more { color: #009DE0; display: "Läs mer"; } .footer_menu { display: none; } And when you look at www.babyproofer.se you can see that not the "read more" tag is changed nor the "Comments and response" at the pages. But the color for "Läs mer" are correct. And this just happened without the client getting into the admin... Thanks! //Åsa
Hello Asa, You are using oldest version of theme. Your 3, 4 and 5th code is working. For 1 and 2 please download theme from your members area and upload it. Please follow link for update instructions. http://www.inkthemes.com/how-to-update-a-premium-theme-by-inkthemes/05/ Thanks & Regards Nitesh Raghuwanshi
Hallo again! I've updatet the theme but it still doesn't work. The problem is the change of "read more...." to "Läs mer...". Now Iv'e changed the two words in the php-file but I would like to solve it in the Custom CSS so that I don't have to do this each time its a new update. What could be the problem? The same thing goes for "Your Name:", "Your Email" ... and "Send" at http://www.babyproofer.se/om/kontakt/. Thanks! //Åsa
Hello Asa, It is not possible to make these changes through css. But yes to save changes done in php file. You can use child theme. Download child theme attached. For more info. http://www.inkthemes.com/httpwww-in...way-to-save-themes-modification/02/?no-dialog Thanks & Regards Nitesh Raghuwanshi
